SC400TT
I actually worked for Corky back in 1989-1990 and he described the importance of ducting to me while he was evaluating a top speed RX7 in the shop with a horizontal mount intercooler (parallel to the road)(one of the few packaging options). I was also able to read some of the chapters of Maximum Boost as he was writing it. Lots of knowlege there but the world of boosting has gone a long ways since then and there are some really talented builders and tuners (along with many more "less" talented)
Ryan, re-install the front under cover, fit foam between the side edges of the intercooler to a/c core and from a/c to radiator. You want the ONLY option for the air to flow is through the cores and possibly into the turbo inlets if you have plumbed cold air induction (almost always a good plan). This combined with your new fans and removed "blockage" will probably be enough for moderate street duty depending on how much power you make and how long you make it for.
Oh and make sure you do not have the same problem as BlackUZZ31
John,
Got it. WHo is blackuzz31?
Ryan
