Hey guys, i am here to resurrect this thread! Ill update you guys on where i am at now. Parts acquired:
Freshly rebuilt v160
v160-1uz adapter plates
Supra 3.266 LSD diff
Supra TT axles
and all the other little parts to make them work
Still needed:
custom driveshaft
custom flywheel
Two days ago i began work on removing all the drivetrain after the tranny. It was all very straight forward. The supra axles are exactly the same as the SC400 axles, just a little thicker, but not much. I still need to test fit the differential, but im not too worried about it as it has been done before so im not concerned with it fitting. Ill be making some solid differential mounts, and thats why ill be putting off installing the new diff and axles.
Yesterday i worked on everything that needs to be done to remove the engine, all not very hard, minus the AC compressor, man the bolts are such a PITA to get off.
Prep
Today i pulled the motor, (my first pull ever) and it went very very well.
were did it go?
next i will be fabing up a flywheel, and when done, a flywheel company will be making me a one with the final specs. also ill be doing a lot of maintenance and relocating the battery and replacing my whole front end
