THis started to happen after I cleaned my engine. At first the car would idle at about 1500rpm then slowly start to settle, figuered I let the car sit to make sure no moisture was causing the problem. After a few days, the car ran fine for about ten minutes, then all of a sudden it dies when I came to a stop. Now the car won't start unless I press the peddle a little bit and control the idle with the peddle. The car does run when at speed, just dies when at idle or wont start without my help. Seems like the ISCV is not working but I don't got a check engine light coming on. Before I go tickering, I want to make sure with any advice to see what my problem could be. Also want to make sure the ISCV is located at the fron of the intake manifold.
:werd:
:werd:
