hungryforinfo
thanks again 1ndecent, I have removed PS pump and begun conversion, I am going to have the belt go around the alternator, across the crank pulley inside the hydraulic pump, around the top idler across the top of the tensioner and around the alternator (start) so it should get good contact, and only need a small belt... it should be quite small and hopefully generate more power than stock..
I have a 1995 with all the plastic on top....
Any chance anyone has tried just doing the electronic fix as mentioned on toymods????
I would rather try it as it sounds faster and easier...
