My stock power steering pump has to make way for turbo manifolds. After toying with the idea of installing a 12V electric pump I decided to go with the hydraulic pump which powered the hydraulic radiator fan in the JDM SC400 the engine came out of.
Unfortunately, several months ago I had chopped the pulley off the this pump, in order to remove the front of the pump. This was required because I needed the pulley gone to clear the belt run I have been using with the AC removed.
The pump pulley covers some of the bolts holding the front of the pump on, and the taper fit pulley required a puller for removal. Because I had already installed and filled the radiator, which prevented access with the puller, I impatiently used an angle grinder to cut the pulley off.
This came back and bit me in the arse, as I have now spent ALOT more time trying to get a pulley back on the pump.
Peewee kindly dropped off another hydraulic fan pump this afternoon, of a slightly different appearance. It is a vane pump made by Aisin. The pump from my motor is a gear pump made by Denso.
Because the two pumps are different, I couldn't swap pulleys. The pilot valve for flow control on the Aisin vane pump has had the wires hacked off flush, and is not interchangeable with the Denso unit, so I can't use the Aisin vane pump.
Now I am really regretting hacking up the pulley on the Denso pump!
I don't suppose anyone in Perth has a spare Denso pulley or Aisin pilot valve?
