Hilux surf 4wd shifter solenoid wiring ?
5020Chris
Hi, just about finished my hilux 1uzfe transplant and am stuck on the wiring up of the 4wd controller on the back of my r151 gearbox. Could anyone point me in the right direction ?
Have set up a relay for the solenoid in the glove box, just unsure of the wires. Gearbox is ex 1994 2.4td hilux surf. Thanks in advance,
Chris.
Should and will still work as standard but you need to remember to put the VSS input back into it. That wiring does not come out when you remove the 2L-TE wiring and is independant to engine wiring. Just remember to hook the earth back up which is a brown wire
