mickesanda
Battery relocation
I relocated the battery today and turned the fuse box 90 degrees CW. As promised i took a lot of pictures:
6 meters of 60mm2 copper wire
This where the cable goes into the boot
You need to find a suitable place for this component, make sure its not wired to the ground
This is the part you won't be using anymore
The cable goes under the backseat on the drivers side
and up besides the the fuel ECU
2 screws hold the plastic bottom of the fuse box.
A spacer was needed
Use the old screws that held the plastic cap
Sideview - i'll manufacture a new bottom later to keep moisture out
The old tray came to use. Find a place with thick sheet metal and drill a hole for the ground.
I had a plastic box for marine use, but it was so big that i ditched it in favor of the old tray
I'll manufacture some nice cover later on.
Hope you liked the pictorial and that it will be of some help
/Mike
A spacer was needed
/Mike
