When you say the engine is running badly, can you be more specific? What conditions are present for the engine to act up?
Also, its best to use the OEM supra TT pump (255lph) as it works efficiently at high pressures (an FMU can crank fuel pressure over 100psi. From what I hear, the walbros do not like operating that high.
If you have 4 big injectors and 4 OEM injectors, then the rich fuel issue still is still present.
Yep. I misunderstood indeed. Lol. That FMU looks similar to what I used. You'll need to put the OEM fuel pressure regulator back to connect to this FMU.Steve, I think you misunderstood... I changed of course all 8 injectors back to stock, why would I do such a stupid thing as changing only half of them ?
/Mike
