Yeah I will do the engine build(ish) when I go FI. I am looking for some spare heads for my mate to flow and build (port, valves etc). He is a total head porting guru and gets incredible flow results. I want to make 500WHP with as little boost as possible.
A company here called NZEFI did the loom, they did like 3 1UZ looms while they were making mine, thats how many they are doing! Its a totally new loom, new connectors where reasonable (like injectors plugs and relays etc). Since its a custom fit loom it goes through the firewall using the stock rubber housing like OEM, but more discrete. It actually uses the Links loom, so it plugs straight in to the Link obviously. Its all housed in the black stretch sheathing too, which is a nice touch.
I have decided to keep the Tilton Triple plate metallic clutch, it seems anything less just wont hold up to the power I want on a reliable basis.
yeah car was a GE, I dont think I would pull a GTE out! Too expensive a car to do that to... GE are less than a third the price here. The GE had the option for LSD, and I have that option thankfully
I wont be using all the GE driveshaft, I am hoping the MKIII turbo front half will bolt to the box and fit close to the mount and the rear half will bolt to the diff and hopefully be about the right length... will find out next week, else just make a new drive shaft to whatever spec. But I like the idea of the rubber disk on the end of the rear shaft to dampen the launch, though it may rip apart... will see.
yes using the R154 out of a 1JZ Supra. So the shifter is at 2JZswap.com getting modded to the rear position. I am making a cross member (trying to), to mount the box since it is slightly too short for the chassis.
My car is in a show this weekend, and while I was there visiting and measuring up so things to fabricate next week, 3 guys came upto me planning on doing the conversion after seeing mine. Not cool! haha oh well.
