Having an exhaust larger then 3" would benefit me, but I don't "need" it. Ah well, we'll see what happens I guess, if worst comes to worst, I can run dual 2.5" pipes on each side and get the same volume
Please let me know, and if you could, a good shot of how it would look if you looked straight down the side of the motor (from the radiators point of view) to see what I'm working with ... I would greatly appreciate that!
2UZ, FWIW, BoostLogic & Chris Johnson sell & run a 4" exhaust system for the MKIV Supra, so "if" the SC400 & the Supra share subframes, you should have enough room.
I thought that too, BUT they don't have a turbo on each side or turbo runners and the downpipe occupying the same area ... and the motor mounts are different because they have to be fabricated, plus the steering rack assembly will be in the way on my drivers side, so I'm still concerned :boggled:
yeah got the bellhousing bolted up with a Tilton triple plate clutch and custom fly. Just waiting on some hardware... and gearbox mount and driveshaft to be made...
I think the V160 is one piece? Hence only can use adapter plates (x2). You may want to read further into that though...
Bellhousing was $650, flywheel and clutch was used for one race but supplied with new disks for $1300. New the fly is about $350, and the clutch can generally be had for $1500 ish second hand with new plates...
Well slight update...
Got the custom bellhousing and flywheel and Tilton clutch and hydrolic release bearing. Probably a month its on the road I am guessing all going well...
