JBrady said:I am glad you fixed the misalignment of the exhaust system to the header flanges. When people force the pipes to fit and tighten bolts tension is created which leads to cracking and failure. I do not know if the misalignment will be a problem with every set of these headers but the whole idea of a direct bolt in was a big selling point.
What a pig of a job, my god. I will never do it again if I can help it.
Not only were the flanges misaligned, after forcing them over, they were not flat with each other. Huge exhaust leak on both sides.
In my mind, even if there wasn't an exhaust leak, the problem had to be properlly fixed. I also modified the bracket that connects the the headers to the transmission, this in my mind also was a must to keep any flex in the exhaust system downstream and not on the head flanges.
JBrady said:I am not digging the downpipes or the H pipe. It looks like the H pipe (which you had added previously) joins the stock pipes 50mm (1.97")with dual 2.00" pipes, those go to resonators and then MAYBE 2.25" pipes to your 2.25" Magnaflows. This is all OK although crush bent piping. What I don't like is the position of the H section. It is where the pipes are bent toward each other and this will allow the inertial energy to charge back up the opposite pipe. I would located it a couple inches past that area where the pipes are parallel or use a Y or X design instead. Caution: all Y and X designs are NOT equal. I am not a fan of the Magnaflow X. I send people to the Burns Stainless site to see a PROPER design.
I don't like the header back exhaust either. All of the rest of the exhaust was done before I had even thought about supercharging. Although, I'm fairly sure that all the piping back to the resonators (except the small section of stock piping that is left of course) is 2.25 inch and from the resonators to the mufflers (dynomax super turbos BTW) is 2.5 inch. I'm not sure why the guy used 2.5 inch in the back since the mufflers are 2.25 in / out. I will eventually get it redone.
So your reffering to these? http://www.burnsstainless.com/Crossovers/crossovers.html
I will eventually go with an x pipe or a y to y.
JBrady said:On the downpipes It looks like your exhaust guy used 2.25" pipes from the header collectors (collector diameter 2.50"?) and those pipes slip OVER your stock 50mm pipes. This creates 2 separate negative transitions. First is outlet from collectors to 2.25 which is a step and then the 2.25 to 50mm which is another sharp step.
I didn't think to measure the collectors on the headers but I think it's actually 2.4 inch. I may be getting the EKT y-pipe from Chase and he had said that it was 2.4 inch piping.
JBrady said:Now, I know you want to go straight 2.5" pipes. This would eliminate the steps. With your supercharger you may do fine with 2.5" pipes although it will take a complete re-do of your system and may hurt your low end response and power.
My system needs a complete redo...LOL. Need to find someone who knows what they're doing as well.
Since the headers are installed and I still have plenty of low end, I'm not really afraid to go 2.5 inch. I think I actually have more low end now than I did with the stock manifolds. The only thing I have noticed is a slight lack of response when accelorating lightly in 4th gear. This is the only time I've ever noticed it, respone everywhere else has seemed to improve.
I do have a question though, would you consider crush bent 2.5 inch piping a good comprimise between 2.25 and 2.5 inch piping? Assuming of course that the bends are not too bad.
Thanks for the input. BTW, I plan on going to the track tomorrow night and I'll be sure to post ets and mph's. It's only an 1/8 mile track but it's the best I can do for now.
KC
