viper92086
I have a build thread already on supramania.com. but i figured i'd throw up some pictures here as well. As for some quick specs i will be using twin stock ct-26's i had leftover from my 7m motor. I will also be using a maftpro setup with 7mge green injectors (315cc i beleive). This is the same computer setup as another member on this forums. Also already installed into the car is a walboro 255 pump.
Here is the link to the thread http://www.supramania.com/forums/showthread.php?t=96332
I will mostly be posting pictures (cut and paste from supramania) here of the process. If you need any more details please log into supramania.com.
Day1
Bought a sc400 1uz with ecu for $400 on craigslist. Motor has 85k. I am still in need of a engine harness. I never realized how hard it is to find one!
Day2
So i got my old 7m outta the bay and we are working on some custom mounts. After pulling the 1uz close to half a dozen times i think we finally figured out what we are going to do. Luckly the stock 1uz engine mounts are fairly close in proximity to the pre89 mounts on the subframe so our plan is to cut off the pre89 subframe mounts and reweld them in such a way it will work with the 1uz mounts.
I also ordered my w58 adapter and flywheel from uza70.com, so hopefully those will come in soon. I just need to find a engine harness now. If anyone knows where i can find one cheap, let me know.
the poopra feelin a bit empty
mmm tight fit, i'm going to modify the brake booster with a big ol hammer.
so i did some more test fitting and i just hit a speed bump.... radiator wont fit.. doh... so i have 2 choices.. get rid of the TT project or shift the radiator to where the condensor was... well i went with plan B. i'm on a lookout for a radiator that will fit in the condensor location with minor adjustments. Also does anyone know if it matters which way a radiator flows? i found a 3 row mishimoto that may work but to route the hoses cleanly, the flow is reversed. on for pics! (approximate location where turbo will sit)
got home early today so i was able to do some custom trans work. I still need to mount the slave cylinder. but so far it works like it should. excuse my redneck fab skillz lol, im just a young guy with a grinder on with the pics!
 on with the pics!
first pic shows the size difference of the w58 bellhousing and the 1uz.
Thats better. thanks to jacks adapter
first step to gettin the shift fork setup to work is to cut out the pivot from the stock w58 bell housing
Day1
Day2
 on with the pics!
 on with the pics!first pic shows the size difference of the w58 bellhousing and the 1uz.
