Bob,In your photo, you have the bolt tab running in line with the oil passage. It needs to be to the side, like in the diagram, so it doesn't it the oil galley
Sorry, but I have to disagree with the engine builder. I have rebuild several motors that had squirters and have never had a problem to this day. On top of all that, I dont/cant see why a builder cant get within the factory tolerances.
Now on a different note about the squirter, they really offer no benifit for normal everyday street use unless its a motor that is under constant heavy power loads like a truck engine that is constantly hauling heavy loads, or a road race engine that spends far more time under heavy power loads then under light power loads. IMHO, turbo motors stand possibly a small benifit if any at all from having them. Again, this is just my oppinion based on what I have seen in motors that I have dealt with.
Bob,
You have to be careful with the tap. The oil gallery is very thin. It about 1/8" thick aluminum. To stable the oil ject I would suggest you weld on an aluminum piece to the it down tight.
Chris & I decided we wanted to use oil squirters in our application. Here are some photos of the squirters as we were putting them in.
Hopefully you can see what I meant by the squirter should be turned slightly so the squirted is put in the corner of the cylinder to avoid the rod, and piston.
We also noticed that the aftermarket rods (Pauter) don't have an oiling hole that the stock rods did have. the oiling hole supplies oil to the bottom of the piston, and the piston pin.
If your thinking of running an aftermarket rod, and don't want to run the squirters, make sure you have the manufacturer put the oiling hole back in, or it may lead to a piston/pin problem.
In the last photo you can see the squirter in the bottom right corner of the piston (If round pistons have corners) LOL
Bob,
Your dedication is admirable. After you finished this Getrag tranny project, could you put up the details of the completed parts and who or where you got them?
Hey all,
Now thats an interesting way for a making a flywheel fit the starter ringgear on the flexplate, where's the flywheel and clutch pack from IOf I may ask? and the gertragbox is that a BMW M5 one perhaps?
regards Thomas
