Well guys, I had the motor assembled with the stock rods, and was having an argument with myself about it.:argue:
After spending all those day looking at it, and something telling me not to run it with the stock rods, I broke down, and got a set from Pauter.
Chris & I are also putting in the oil squiters off of the iron block.
The rods from Pauter are labled Tundra, 4.0L I'm not sure if the rods are the same between both motors.
David do you know the answer to this?
The pin end of the rod is wider then the stock 4.0 rod, which is nice for extra strength, but Chris thinks it may not allow the piston to move as it should.
Were gonna check this out over the next few days, and will let you guys know what we find.
Here are a couple photos I took of the Pistons/Rods.
