Kit include almost everything you need.
Just look at the picture
http://i392.photobucket.com/albums/pp4/raceraudi12/Boat Part Pics/AEMINJSYSTEM.jpg
It's from big block chevy engine.So you could use current map with few changes.BBC has same firing like 1uz
The list:
Aem Ems 30-1050 (for Honda)
Aem Uego wideband with two Bosch o2 sensors
Loom for v8
Cam sensor,water temperature sensor,inlet air temperature,very nice and expensive map sensor,oil pressure sensor(connected to Aem ofc),fuel pressure sensor,crank pressure sensor.
A lot of other electronic stuff.
Package weight is 7,2kg
Used for only couple of hours.I don't need this because I'm going 1jz and will be using piggy back![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
I want 1400usd for whole setup
The list:
Loom for v8
