Buy two Echo heads !! The shimless buckets fit..
Btw we buy parts Stateside from down under..
It wouldn't be too much of an issue to buy from here...
GTR retainers would be cheap and light to post also..
I was putting regrinds into heads that had already been shimmed with stock valves and stock cams, so with the regrinds we had up to about 8.9mm clearance between the heels of the lobes and the valve stems.
The thick 5.74mm Prius shimless buckets took out most of that, but we still needed shims under them.
We were running stock springs on that engine, but the next one has Lextreme springs in it, and will probably have a set of Kelford cams.
Its not going to provide great lift. The lifter under the cam has no multiplication effect. It being taller is just going to make your valves not seat properly. Yes it will create more lift from the seat, but not lift as in total travel of the valve. It wont shut if this shim/bucket is taller than the stock ones and the cams are using the same base circle as stock. If I move my finger back and forth 2 inches with my hand in front of my chest, it moves 2 inches. If I move my hand out away from my body a foot, and move my finger 2 inches, it still moves 2 inches...Get the idea?
