I got a chance to noticed the bucket differences between the two engines. I am not sure the valve stem length of the 2UZFE, but from what I see the buckets are different. The 1uzfe bucket is pretty much flat with no noticeable raise. However, the 2uzfe has about 1/16" raise. Assuming they both have the same valve stem length, then the 2uzfe should have greater lilft. I wonder if we can use the 2uzfe bucket on the 1uzfe heads for greater valve lift.
Beside the greater bucket seats, there seems to be an additional shim also. The 2uzfe and all the VVti heads have a space on the retainer for a shim. Check out the pictures..... The last picture is the 1uzfe bucket.
I wonder if we can use the 2uzfe retainers, shims and buckets on our 1uzfe heads for greater lift for more flow.... What do u think?
