i need info regarding running 2 AFM's for a twin throt setup in my 1UZFE MX83
1. Can you simply wire the 2 senders in parallel, then off to the ecu using a resistor network to compensate?
2. How hard is it to convert to MAP sensor? ie: will the stock computer run OR can it be wired into the stock ecu?
any tech info on this topic will be great
