To get the tread back on track
sniper:
I try my best, if I'm not 100% satisfied, I redo stuff. This means everything takes forever but that's ok and
the MOT will not have any reason to go say, that's not good enough so we can't give your car an ok....
deankdx:
No need to get a job at the MOT, I just needed to know how the system works. What I ended up with was
3 approved Ford Sierra applications on Saturday, one estate ( XR4x4 ) with an engine change to a 1UZFE
engine, one 3 door ( 2.0 liter ) with an engine change to a 1UZFE engine ( RWD only thou, as the car is RWD
to begin with ) and one 4 door sedan 2.0 4x4 to Sierra Cosworth 4x4 2.0 16v turbo ( need to get rid of all
the parts I have assembled thru the years. )
4x4 stuff:
I have done a lot of research to find a manual gearbox with constant AWD capable of dealing with
850 lbs/ft
( 850 HP ) at the flywheel, this is my suggestion for a solution:
- A 1UZFE bellhousing ( I'd prefer a U2 for several reasons )
- Adapter plate to Tremec T56 gearbox ( I have drawings, let me know if anyone need 'em. Remember, tell me
if you have a U1 or a U2 bellhousing ).
- A Tremec T56 gearbox with the following specs:
- Dodge Viper input shaft ( 26 splines and long enough to be used with the 1UZFE bellhousings + an adapter
plate ).
- Custom main shaft, to "suit" a Aston Martin V12 Vanquish, this means separate 5th ( 0.80 ) and 6th ( 0.62 )
gears and thicker overall main shaft size ( Arnout on this forum can get custom T56 main shafts made to any
lengths and any splines at the end. )
- Ford Mustang 1st to 4th ratios ( 2.66:1 , 1.78:1 , 1.30:1 , 1.0:1 ) and front housing. ( Hey, I'm a Ford guy
but you can use any T56 housing. The drawings I have for the adapter plate is to the Ford front T56 housing,
I think they are similar but YMMV :shrug: )
- A Chevy Corvette C5/C6 Tremec T56 rear housing, this has a flat flange at the back, makes is easier to bolt
an adapter plate onto it and the center diff onto the adapter plate.
- Center diff. Now it get's tricky, there are two ways of doing this, it depends on where you want the center
diff, on the right or left side of the gearbox.
To have the diff on the right side of the front sump, use a R32 Skyline center diff + various parts.
To have the diff on the left side of the front sump, use a GMC Syclone/Typhoon center diff or a Chevy Astro
4x4 van. This is a Borg Warner 4472 constant AWD ( 34%/66% F/R split ) center diff.
- Right hand side front diff, use a Skyline R32/R33 4.1:1 front diff ( the sump has to be modified a lot, the
best solution is to run a dry sump, I'd recommended this at this hp level anyway. )
- Left hand side front diff, use a Ford model 35/194 front diff ( 1995 - 1998, with CV, Ranger and Explorer )
with 4.1:1 ratio. ( This is separate from the front sump, makes is possible to retain a wet sump, but I'd still
recommended a dry sump anyway. )
The 4.1:1 front diff ratios also means you will need a 4.1:1 rear diff ratio. The 4.1:1 ratio is chosen as it gives
an an ok final ratio ( 5th gives 3.28:1 and 6th gives 2.542:1 ), remember the 1UZFE is only 4 liter and you
can't go silly with lower ratios and expect the car to perform.
