picked up a cheap damaged soarer sc400 and will be transplanting the engine and box into my 67 HR Special sedan also using the front stub axle assembly from the soarer and a Skyline borg warner 3.7 LSD preliminary fitting I almost crapped myself as the engine sat too far off the firewall about 3" too far due to the wiper motor so the engine came out and all discrepencies marked to be cut out of the way then it went back in fitted much better and the crossmember was notched will be using a CRS modified front mount torana rack when it finally turns up so it will be positioned first then the mounts will be made gearbox mount is almost in the same position so just a matter of modifying the holden mount to accept the toyota rubber mount. this is my daily or side tracker as my wife calls it from my Datsun 1200 ute project i'll post pics of both. the last pic hints at whats in stall for the old girl you see i have a few left overs or as you could call them cheap impulse buys in the form of a 600x450x80mm intercooler a heap of CA turbo injectors from the datto an e-bay t70 turbo 40 mm wastegate and an EMS should be fun the only problem so far is the rubber donut on the 1uz box but having a complete 1jz setup lying around i noticed they use a normal yoke anyone done this before eg swapping bellhousings to use a 1j box are electrics the same .
Nick.
Nick.
