samsdad Member May 16, 2011 #2 Sensor for 154 is? They only have the reverse light switch and neutral or first gear position switch. VSS is part of the speedo in Toyotas
U ugp New Member May 23, 2011 #3 There's a speed sensor on the box, that feeds the dash + ecu for a speed signal.
mshawari1 Member May 24, 2011 #4 You could fabricate your original car sensor to be installed on the R154 ... OR ... have a middle signal modulator adapter to use the OEM R154 with your car OEM dash speedo.
