Ok. So I downloaded all the FSM's for it. Like I said it's mainly the cam profiles.
The exhaust cam remained the same. The intake cam went from 232* duration to 230*. Lift has been added on the cams. (0.01" for each) The differance being that the intake cam can spin an extra (maximum)*20 of advance/retard. (Retard accounting for alot of the past pre '97 horsepower peak gain, i.e. the not so fast fall off.)
Valve size increased to 34.5mm(33.5) intake, 29mm( 28) exhaust. (Hey that's been the v6 valve sizing since '87) Valve stems shrunk from 6mm to 5.5mm.
Sissors gear moved from center of cam to front of cam.
The intake manifold gained ACIS. (Which we v6 owners hate. Yall have the type of system design we should have...) A good portion of the horsepower Looks to come from the ACIS that actually works.
You can see the bump of the ACIS flap going from closed to open to shorten the runners in the provided dyno.
***Modification opportunity***
Toyota is sorta like Honda when it comes to ACIS/Vtech. We v6 owners find that the ACIS activates abit too late. By activating it earlier, you can get a few horsepower for a few hundred rpm where you wouldn't have it. No big deal.
Intake manifold gasket is multi-layer steel, with a composite core to reduce heat soak to the manifold. (Think cheap OEM insulating gasket. I use to sell them to the v6 guys for $15 a pop made out of 1/4-3/4" aircraft ply. Mine worked... Heat soak was markidly reduced after a 1/2 hour of run time, in the order of 15-25c on my CompUNurse.)
The compression bumped 0.1 CR (10.4:1 to 10.5:1).
Intake ports were made more upright.
Combustion chamber & piston face change to tapered squish.
Air assist was added to the injectors (dang we had that in 92)
Injectors went returnless, 50psi and 4 hole.
Direct ignition
Muffler change (longer tail, but the schematic of it looks like it has better bends in it...)
That's for the 98 LS, the 98 GS seems to only really differ in having the slightly better style exhaust manifold & straight through resonators.
A 3 stage electric cooling fan, 3 stage fuel pump & the fuel pump was moved in take to a jet version.
That's about it AFA I can tell by readng the papers & outlining it. But it's pretty much just the cams. Take your pre '98 cams, retard them 20*, and you'll likely have shifted alot of the powerband up top.
I can tell you, the similarites at reading the v8 papers to the v6's I work on all the time is huge. Reading them more in-depth, Personally, It's like looking at the 94, 97, 98, 01 1mz-fe's & the 03 3mz-fe. The parts look nearly the same construction in the drawings. The feature lists of constructio & modifications are the same. The dimensions for various parts of note are the same, if not very similar.
The cam profiles are within degrees of each other... The lifts are the same terrible sizes...
For instance. All the 1uz exhaust cams differ from my engine's only by 1* of duration. Doesn't mean the profiles are about dead wringers, but there you go...
It's 4am. I've been on techinfo for way to long. Have a good one.
