- Messages
- 5,632
- Location
- Sydney, Australia
You can delete the ECT easilly without upsetting the engine ECU.
If you look at the wiring post put up by KDog (its a "Sticky" so is at the head of the electricals section) you will see there are a few wires that run between the ECT and the ECU. All of these can be cut as they are not required.
Essentially get rid of every wire running to the ECT and run you manual.
The ECU won't care.
I've done this in my car and it works well.
The ECU won't care.
