Peak & Hold driver, these are used to correctly drive low impedance injectors.
Some ECU manufacturers advise that their boxes can drive low impedance injectors with the addition of a resistor in series with each injector.
This scheme simply limits the amount of current the ECU has to output, and the injector doesn't open as fast as it should with a true P&H driver. Sometimes it's not a problem, but it can be noticeable if you're running some really big (like 1600cc) low impedance injectors and you can't get them to idle properly.
Actually this is the way Toyota, Honda and other OEM's drive their low impedance injectors, so I suppose it works, after a fashion, but the injectors certainly don't open as fast as the injector manufacturer intended them to.
AEM's ECU is like this, so to their credit they came out with a separate P&H driver box if people want to drive low impedance injectors correctly. Here's a link to this box: http://www.aempower.com/ViewCategory.aspx?CategoryID=83
BTW, the Prins ECU is already setup with the correct P&H drivers, and costs less than a standalone plus a P&H driver box.
And although the above might sound like a sales pitch, no I am not a Prins salesman....
