litldv8
- Messages
- 65
- Location
- toowoomba australia
1992sc400 with 40 40 40 pin ecu
I have put it all into a Hilux
I had a few dramas with knock sensors
Firstly new dead sensors then wrongly boxed sensors
But finally sorted
I now have a 3750 rpm rev limit
It will rev out properly sitting still
It has a manual gearbox behind the motor
If I keep it under 3500 rpm it drives fine does not matter which gear I am in
If I disconnect the vss wire it will rev out in all gears but the check light comes on
No codes with vss connected
Any clues?
But finally sorted
Any clues?
