Doug68
Hi All,
I've been scouring the site but been unable to find links that match up with my engine. So the code on the ECU is 89661-30500, which from searching other threads should mean its from a:
1991 UZS141 Crown Majesta
89661-30500
175000-4911
pins (same config as soarer/sc400)
plug 1 40+40p
plug 2 40p
The motor is a Jap import and was billed to me as coming from a Celsior if that makes any difference.
The O2 sensors on the engine are single wire, the only diagrams that I've found have been for two or more wire O2 sensors.
I believe I have the engine loom fairly intact, but for the the 3rd of the 40P plugs I just have the plug and a stub of wiring, similarly for the fan ECU and the traction control unit (neither of which I will be using though.
I assume that there must be another loom that they plug into as theres not obvious hacks on the engine loom.
There is also this plug (see attached), which is not for the ECU, which I dont know the purpose of...
So does anyone have the wiring diagrams for the engine setup I have?
Thanks,
89661-30500
175000-4911
plug 1 40+40p
plug 2 40p
Thanks,
