Sorry for the delay in replying. The 6 pin you have correct and the 4 pin has the coil power and trigger. In the four pin there is also a pair (often a black wire and blue/yellow wire) which go down to the hydraulic fan pump solenoid. Where the hydraulic fan pump has been removed I use one for the oil pressure sender and the other for a electric fan switch. If you want some more help flick me an email at kelvin@thecartunecompany.co.nz Or send me the air ticket and Ill come over and give you a hand. Cheers
