Now I may be wrong on this, but I think I'm right. (So someone correct me if I am.)
That F1 engine isn't using accoustic charging anyway. It's using ITB's with a pluemn over them, which work via a seperate principal & math & sorts.
I don't quite see what you're showing me with that that 3s-gte manifold. To me, it looks inline with what I said. Compair that pleumn volume with a stock one, with the rules of thumb I outlined. That looks like many quality, high end aftermarket i4 manifolds. Shortest runner possible, large pleumn for boost. The really good ones taper to the farthest intake port to keep velocity i4's, I don't keep up with & probably should.)
Look at that manifold VS the stock ones:
I'm not a 3s-gte guy, but keep in mind many high end 3s-gte manifolds also do away with TVIS all together.
To quote MRControl's big 3s-gte article
![st215manifold4xo.jpg](http://img116.exs.cx/img116/2530/st215manifold4xo.jpg)
![st205manifold2zd.jpg](http://img116.exs.cx/img116/2985/st205manifold2zd.jpg)
![st185manifold8ts.jpg](http://img116.exs.cx/img116/807/st185manifold8ts.jpg)
I don't quite see what you're poining out showing the custom 3s-gte manifold. You can't see into the carbon fiber, but it looks like shorter runners, more pluemn volume to me.A properly designed intake manifold with a larger surge tank than stock is critical to making safe power above 350rwhp.
