Let me try again
Early Vss - 83181-50010 Listed for USDM until 08/92 but listed for some other markets for the whole range of UCF10. Seems pretty much lexus only
Later Vss - 83181-24040 Listed for a wider range and also seems to be used in some models back until 1989.
The early sensors I tested today are JDM and 4 pulse per RPM. There is also a later auto at the back of the shop with a VSS in it. I didnt test that one.
Funny enough after playing with sensors this morning I had to sort out a suitable sensor for a conversion in the shop. I ended up fitting an Isuzu one as the toyota ones had the plug going the wrong way and I didnt like the look of it. No issues with pulse count as it is having an aftermarket ECU which I use as an signal modifier. Will have to modifiy the signal into two different outputs to run the trans controller and the speedo.
