I read a lot about how close a well ported non vvti 1uz head will flow identically to a vvti stock head.
My Q is that, how hard would it be to swap a 1uz vvti head to a non vvti 1uz? since i'm not using vvti, the only mod I can see is welding the vvti ports right?
-Im guessing I would need either a custom manifold or a stock vvti intake
mani right?
Nope...all the oil galleries are different not just those to the VVti. So basically you'll need to block the stock galleries in the block and tap into them somewhere to run an external oil line to the head. I looked into this and it would be a PITA of major proportions to get it all right.
I gave up![]()
mmmmm interesting, keep us posted Justen.
My next step is to delve into a set of heads to make them flow better along with some cams. I'm not particularly interested in VVTi set up but the coil on plug and better flow capabilities is starting to excite me.
I'm note sure if there is an off the shelf supercharger manifold for these heads yet? I did hear rumors there was one in the making?
All u need to do is to thread a 1/4" npt plug into the block where the oil supply to the vvti and u are set. However, since the pre and post heads are different design you might need to change out the pistons.
JBrady:
I was thinking of using the high flow charactaristics of the VVT heads but do not need the VVT function. So if like you said, the lube circuits "line up" with the ports on the early uz, this could work? Would we be able to use the vvti cams as is or would early ones need to swap over?
IS300 guys delete vvti, you have to get non vvti cams machined to fit the vvti head. And remove the solenoid.
