You can swap the heads, but you will need everything else from the heads and above. The heads by itself will NOT work. The lower intakes are different angle. Unless you have an adaptor that mate with non vvti lower intake to vvt heads. The heads have different intake angle
everything else from the heads and above mean lower intakes, upper intake, TB, sensors, plugs, injectors, fuel rails and other misc. FYI, you will have a hard time finding the proper size timing belt. I am not sure if VVTi timing belt work on 1uzfe crank pulley (timing pulley)
