JDMfantasy
Some engines simply have casting that extends down into the airway (port) which you can grind down fairly easily. In our engines, the steel sleeve extends down into the port almost a half inch....
....can these valve guides be removed? I would like to take them out and cut them down flush with the port wall. Is this possible?? Are the sleeves just pressed in?? Anyone with info jump right in...
