Hi, I have a 1UZ wired into a landcruiser and it won't kick over. Just curious if there is any glaring problems with what I have wired before I go pull my hair out faultfinding.
Some background.
1. I have searched these forums for over 2 hours to try to find my mistake(s).
2. I have a ***220 ECU. 40/40/40 pin.
3. I have hard wired the fuel pumps in temporarily to a switch. Will change this later when the engine is running.
4. Engine has an UNCUT loom, so i'm assuming all the sensors etc on the engine are correct as they're as per factory.
Ok, this is what I have done so far.
* +12V wired to pin E9-33 (BATT)
* Pin E9-24 (M-REL) drives the Main EFI Relay.
* E9-31 (+B) and E9-32 (+B1) both get 12volts when the Main EFI Relay is switched.
* Main EFI Relay appears to be working fine.
* Pin E10-4 (E11) is grounded.
* Pin E10-65 (E2) is grounded.
* Pin E10-79 (E02) is grounded.
* Pin E10-80 (E01) is grounded.
* Pin E10-77 (STA) gets a 12volt input from starter relay when the engine is cranking.
* Pin E9-1 (IGSW) gets a switched 12volts from the ignition switch.
Do I need to do anything with the Neutral Start Switch?
Any help is much appreciated and thanks for reading....
EDIT : I have a hydraulic fan on this engine, but my ECU part number ends in 220
This tells me it's a UZZ31 ECU, but I just read that the UZZ31's wern't fitted with a hydraulic fan. Is it possible I have the wrong ECU for this engine?
Some background.
