fruitysupra
Hi all
apologies if this has been covered however i couldn't specifically find the answer to all my questions.
Background on the car: mkiv toyota supra with 1UZFE (older of the 1UZ's) fitted with a holset hx40 turbo at the rear!, chargecooler, and wet shot of nitrous. currently on standard management only running 7psi but with plans to upgrade ECU to run 14psi. also plan for the future to run meth injection.
what i want to do is upgrade the ignition system.
1. im looking at MSD DIS4 after reading a brief write up but was wondering could i not use the DIS2 as only need two channels (it seems a waste to get the 4 but see no info on using a 2). i dont really see a need to use 2 6AL's.
2. im also looking at the AEM 4 CHANNEL UNIVERSAL TWIN FIRE CDI C2DI IGNITION MODULE, 30-2821 which is a cheaper option but haven't found much info on installing on a 1uz
3. im also planning to upgrade to coils to MSD blaster SS's x2, would these be ok with the AEM one if i went with that.
do i need a MSD 8912 Dual Channel Ignition Tachometer Adapter as i run my tachometer from the ECU?
4. the two stock ignitors... i presumming i just remove these and use the wiring from them to install which ever one i go with.
thanks in advance.
thanks in advance.
