Under bonnet air temps
What about restriction in the exhaust? (colapsing cat or muffler)
Can cause over heating & loss of power if really blocked.
Not sure what you've checked or tried so just throwing some ideas around.
after alot of monwy and time i finally sorted it out i think
new 3 core rad was 550 very heavy unit
due to rad being hticker my old themro could not be fitted
so i fitted an 11 in and 10 in fans more money
today is a hot day and with car stationary and bonnet shut
the temps on scanner says 97 when fans on and 95 when fans off
i let it run for 20 minutes and still temps stay around 95
so i think its ok for now
the new radiator has 40 to 50 % more water capacity
and with 2 small thermos i spread the cooling
so it all seams ok for now
mind u after the engine had not been run for 5 days it took few seconds for oil to get up and was bit noisy hehe
luckily i get these engines pretty cheap
hey has anyine had a scanner on their 1uz im wondering if tyhe temps its showing me are accurate or normal for one of these
i have a snap on scanner if anyone wants to get some reading
My 1uz sat stationary for 6 weeks, didn't make any wierd sounds when starting.
Oil pressure is usually up before the motor even starts.
