twin 2.5 inch uniflow intake
LSKid
Finally got my intake unit fron the US & had fun fitting the part as the airflow meter had to be moved back 4-5 inches but fits & works a treat now!
I got this from over there in the US from memory it was R1 Racing concepts!
Ill have to look it up!
Have a look at the inlet to your airbox next to the radiator. Its about 2inches around if that compared to 3.25 inch twin foam filters!
Sorry, I meant 1 large pod filter compared to 2 small ones. Did the kit come with the molded heat shields or did you make those?
Have a look at the size of the standard airflow meter.
Its not *that* much bigger than the inlet to the airbox.
Doing one of the 'BFI' mods from planetsoarer.com is more than enough, and they cost about $15 tops.
