T TURBO100 New Member Sep 20, 2020 #1 What will happen if I DON'T use an aftermarket ECU? As in, what will happen if I just bolt the turbo on and drive it?
Zuffen Super Moderator Staff member Sep 21, 2020 #2 Depends how much boost you're talking. Very low boost the ECU SHOULD be able to handle and the Injectors MAY be able to keep up. If they can't keep up it will get messy and expensive very quickly.
T TURBO100 New Member Sep 21, 2020 #3 Its a 10psi setup, I have some BOSCH 725cc injectors and am going to get a walbro 450 fuel pump. I was just wondering this as its difficult to find an ECU that will run the 5spd auto in my Landcruiser. The fuel side should be fine.
