because photobucket broken links suck
(not my kit, but I wanted to see the pics in context)
First off here's the t56 throwout bearing
On the left hand side it has a slip fitting that is retained by a roll pin
remove the roll pin and the big orange gm fitting slides right out.
Go ahead and toss this piece as it's useless for this swap.
now use the slip fitting that came with the kit and slide it into the t56 throwout bearing.
Then replace the roll pin.
now remove the fitting on the other side and replace with the fitting that's shrink wrapped to a piece of cardboard with a crush washer and be sure to use the crush washer or else IT WILL LEAK!!!
Now you're done with setting up the t56 bearing for use with the braided steel clutch lines.
Chapter II
Unfortunately I do not have any pics right this second for this section. But I'll post the instructions now and the pics later.
Basically you cut the guide tube that's on the bearing retaining plate off flush with the plate.
CHAPTER III
Remove and toss all of this stuff from the automatic.
ABSOLUTELY DO NOT USE THE SPACER FOR THE AUTOMATIC FLEXPLATE BEHIND THE FLYWHEEL!!!!!!
ABSOLUTELY DO NOT RE-USE THE FLYWHEEL BOLTS FROM THE AUTOMATIC FLEXPLATE!!!!!
Now here's the back of the crank. Your pilot bearing goes in here.
next install the flywheel with your new flywheel bolts that you just bought. You should probably get them from summit racing.
here's the link
http://www.summitracing.com/parts/ARP-203-2802/
and here's the flywheel installed with the ARP bolts I bought from summit.
Install your clutch
With the cast flywheel there are several options for clutch setups. Typically I suggest either using the 3SGTE MR2 21 spline clutch kit or the 1990 4runner clutch kit because both clutches work complete as a set with this flywheel.
Install your pressure plate, and now you're engine is prepped for install!
CHAPTER IV
Once again I'm a little short on pictures, but basically you drill two holes for your clutch lines to go out the bellhousing and then bolt everything together Like so.
Now that you've accomplished bolting it together you're done.
