A v12 can have improper balanced internals.Toysrme said:Doesn't matter. It's two i6's joined in V form. No internal balancing needed because it naturally has perfect balance, no heavy flywheel.
Power capped at 280bhp@ 5200rpm 353lb-ft@ 4000rpm.
Construction is a forged crankshaft with cast rods & pistons.
The 1GZ-FE uses the parts bin from the 1NZ-FE & 2NZ-FE, built off the same assemly line.
I am assuming you mean 1MZ-FE and 2 MZ-FE?Toysrme said:Power capped at 280bhp@ 5200rpm 353lb-ft@ 4000rpm.
Umm the production N73 V12 and the S70/2 are not the same engine.SCV8 said:I've also been looking at the newer 4 valve,BMW V12s, they are 6.0 I believe, and if the controlls could be sorted out, would make for a nice motor as well.
These are what the Mclaren engines were based on, basically.
I have seen an older 5.0 version (2 valve) installed in a Z car, was pretty slick.
Sorry to go OT, have looked these engines for awhile, and have yet to see a 1GZ-FE for sale; they are rare.
If a person is looking for this motor specifically, this is certainly not your average person.Lextreme said:Its nice to have a V12, but i would not personally want it. The reason why would be aftermarket support and oem replace parts. That will be a nightmare. However, its a very nice engine and would like to learn more about it.
You won't find a smoother engine than Toyota's JZ i6's (Maybe a wankel). Historically, all v12 +'s have good internal balancing. Toyota's v12 has excellent internal balancing, being mostly based off their previous i6's.A v12 can have improper balanced internals.
Your're using the purpose of a v12 wrong... weight balancing and vibration balance is different the v12 is almost vibrationless because of the design thats why they make them the smoothness.
No, I meant exactly what I said. It's built using the 1NZ-FE & 2NZ-FE parts bins at the Kamigo engine plant. NOT parts bins from any of the v6 family, which are all built at the Shimoyama Plant.I am assuming you mean 1MZ-FE and 2 MZ-FE?
Again its not about internal weight balance any engine has good internal balance today... ITS balancing VIBRATIONand smooth power delivery.Toysrme said:You won't find a smoother engine than Toyota's JZ i6's (Maybe a wankel). Historically, all v12 +'s have good internal balancing. Toyota's v12 has excellent internal balancing, being mostly based off their previous i6's.
