deankdx
regarding this for TOBES and KDOG,TOBES said:KDog,
a late model Falcon. The shifter operates the shift lever on the trans thru park-reverse-neural as standard. When drive is selected the shifter is spring loaded to move to the left into the tiptronic gate, the lever would disengage from the trans shift lever and the trans would select first gear. From there gear selection is controlled by the switches mounted at each end of the tiptronic gate, pull to change up and push to change down. I would remove the lower gear positions from the shifter.
To engage neutral, the lever needs to be pushed to the right, against the spring pressure, and forward making accidental neutral selection unlikely. Not all applications will be as safe as this....
i may require a similar setup and was hoping the late falcon(BA XR6 auto especially) shifter would work in this way,can you confirm?
lever and swithcing is not a prob for me to adapt but i need to know if it functions as required with the tiptronic kit.
thanks Dean
