I might be clutching at straws but I thought of a few more things. The blanked off hose from under the throttle body has an actual bolt in it with a hose clamp, I also used a bolt when testing the PCV hose last night. I guess boost could climb up and out the thread....
When I tried to pressure test the manifold by connecting a blank with valve stem to the the throttle body, all it would do is keep pumping air in and not build pressure, even with the throttle body closed. Is that normal, or should it build pressure does anyone know?
