see the above inlet manifold..thats how i wish to do mine..
spent 2hrs last night,blower next to engine wondering how to mount it WITHOUT spending $1000's on aftermarket manifold that wont fit my jag 112 anyway..
so with measure in hand looks like has to sit in traditional place and stick out of hood a bity..no problem can live with that..also allows me to plumb the lpg lines down into the valves..
think easiest/cheapest way is to keep bottom manifold and build a "shoe box" that bolts on top of b.m. and mount sc on top of that..
now..thinking to myself ali for the box would be nice..but i dont weld ali..shite hot with steel so...
a)pay someone to make box..expensive and not in the i did all this myself thingy i have going.
b)buy tig and learn to weld ali..is it easy or really not.it needs to look good.
c)prefered option in steel....do it myself then..can anyone see any down sides to steel (except the weight)..i guess 6mm plate for base and top with 3mm sides..(40-50mm high)..
thoughts??(should this be in fab section? not sure)
oh did have a wild idea about running sc on inner wing (4x4 remember) powered up by hyraulics.then can vary boost and have a "clutch" at any rpm (to a point)..totally feasiable (trucks at work use this, though not running a sc)..£1000+ for suitable motor and pump though..shame
