Well yes the car is still around but its changing form a little.
First up, the diff has been removed in favour of installation of a shortened 9" F100 diff, and the rear suspension is being upgraded to a 4 link system. The spool center of the old borg warner diff was on the verge of breaking.
The rear end of the car has now been tubbed to allow 12" wide tyres to fit under the guards, and a steel roll cage has also been installed in the car. The entire interior has been stripped. It is now being built up solely as a race car, with no intention of ever being put back on the street.
The engine and tranny got fitted to a $400 VS commodore so as to be an entry in the innisfail car show burnout comp. As described by other people at the show, it was the most over powered piece of **** car they'd ever seen. (broken windscreen and roofing nails holding on the bumpers). But due to the car being finished late it didn't manage a burnout properly. Some hose connections weren't done properly, so the computer wasn't getting correct manifold pressure readings. The result was lean and too much ignition advance. They did get to make a lot of noise with it though, plus managed to get into a little trouble with show officials doing 3rd gear drifting around the show grounds with thr grunt files guys in the car...
Shortly after that, both turbo's failed...(not due to the hose problems, cheap turbo's and bad bearings) So they are being upgraded to a garret something ?? T3/T4 hybrid again... not exactly sure...but its under warranty aparently?
I'm pretty sure the injectors in the engine are bigger than 280cc. I'd guess they are at least 350-380cc. I base this on the look of the fuel map and the amount of boost the engine is running.
If any of you are familiar with the grunt files DVD's, check out the next one because the vs commodore willl be in it.
