fruitysupra
Hi People.
I have a couple of questions really.
1st. i want to add an oil catch can as will be doing some runs at santa pod with the supra once the conversion is finished. Just wondering where the hell it goee i.e which side of the engine.
2nd. kind of similar to the 1st question. i have an induction kit on the engine, (which i know a lot of people are not fans of but i have ensured there is a lot of cold air going to it and also isolated it from any heat sorce.) firstly would it make any improvements adding an aftermarker fuel pressure regulator (like the one in lextreme shop) and if so which side does that go. (i think its the same side as the throttle body but just want to make sure.)
3rd. those of you who have changed your induction pipes to either alloy or silicone, what have you done with the pipe that goes from the powersteering pump.
Any pics or advice would be greatly appriciated.
