Swap 1UZFE-1993 ENGINE IN Mitshubishi Delica Space Gear 1994 4M40 Engine(PROJECT)
Mihnea13
Hello, I have a project started, I have a 1uz fe motor from 1993 with ECU code: 89661-50251 and I don't have a 28-pin coupling or the ECU power plug, if you can help me with a wiring diagram to control the engine start on this couple.
I want to mention that I want to put the engine on the Mitsubishi Delica Space Gear.
