This is an old thread but suggests an interesting discussion and topic...
Root supercharger -
That will give you instant lowend torque like N/A since the charger is run directly off the crank...The engine turns and so does the charger immediately.....The down side is that the charger will use crank HP's to turn it...
Turbo charging -
Spool up time is needed to turn and operate the turbo so lowend torque is compromised greatly..However, the exhaust turbo is driven by the exhaust and not the engines crank so less power is used to run the turbo in comparison to a root charger...
So which would be faster? Well if both were equal in power output... The charger would be faster but the turbo is more effecient ... That's my take when comparing root chargers to exhaust turbo's...
There are other types of boost not discussed such as Centrifigal chargers and Variable vane turbo's.... Not as commonly used though as your every day exhaust turbo's and root chargers.....
Feel free to add to this discussion...
Root supercharger -
Turbo charging -
