sufficient parts???
purplehaze
I have a 1UZ VVTi and planning to mod it to run up to 9k rpm, the parts list includes kelford cams and springs, rods, arp head studs, and gaskets. Is there anything necessary that i should change like fuel injectors or valves?
Not planning on going with oversized valves or very aggressive cams since machining the head is a challenge, in exception to the ports, for now ill run it NA with aftermarket intakes
If you scratch around there was a guy in Australia who built a super high revving 1UZ. Cost him a lot of money to end up with an engine that had very little bottom end and quite a good top end, but nothing outstanding.
If I can think of his name I'll post it so you can find his thread.
