I changed the lower control arm bushings to Daizen since the internet told me i should with the mileage and after inspection i could see deterioration on the rear ones. I ran into a problem during removal, the camber bolts were seized into the bushing sleves. I ended up torching the camber bolts to remove the control arm. 2 problems with that. Slight damage to the rear suspension crossmember, and the remainder of the bolts were left in the sleeves. I tried to weld, and grind my best the make the slots in the suspension crossmember the best i could and match the same clearance of the fronts and thought i did a good job. I carefully milled the bolts out of the sleeves to where there was a fine layer of bolt left and i tapped the rest out. I checked the way the bolt felt in the rear sleeves i milled vs. the front which i didn't and they feel just i tight. Also the the cross member the camber bolt is tightened in place so it shouldn't move at all right? I get a slight clunk over bumps and its quite annoying. I didn't like the way the lower balljoints spin without much effort and the book states a good amount of torque to turn them. Also, would ball joints go out immediately before and after work, it doesn't seem right. Also the car only had 110,000 miles. One friend said it was because i haven't had an alignment yet, did notice the front left wheel has postitive camber. Help! I'm really frustrated with this project, almost wish i hadn't messed with it. Any ideas or tests i can do?
thanks in advance
			thanks in advance
