soarer fuel tank
ek amigo
Had a good search but couldn't find any info , is a soarer fuel tank from a non 1uz model suitable for a 1uz conversion ?
yes but its prob easier to fit an external efi pump to your std tank setup
theres alot of work getting a tank from another car to fit into a different model car
my hilux carby tank took me 20 mins to make it efi
It should be the same including the Fuel pump and Fuel pump ECU as the pump has two speeds. As long as the fuel comes out it doesn't matter what tank you have.
Robert
thanks gents ,the reason I ask is that the car is pretty old (EK Holden ) and the existing tank is only 150 mm deep , I have been told I need a surge tank , high and low pressure pumps , regulator and inline filters etc , just though it might be easier to take the old tank out and replace it with one that goes with the 1uz engine . I would like to keep the old tank though if it makes sense to go with the external pumps , it would look more original , so does anyone have a simple plan.
