A velocity stack is usually longer than a normal manifold runner to get the flow right.
In this case the runner is much shorter than stock so theoretically it should produce more bottom end.
entire rev range under boost?
That could be a key factor here.
Once under positive pressure, runner velocity is not as significant as it would be in a N/A set up.
I'd be really curious to see want happens with the manifold on a N/A car.
Still no dyno but the drags turned up some promising results. No traction on the street tyres so best ET was a woeful 12.1.....60ft not even close to dipping under 2 secs BUT trap speed improved by 5mph to 125mph. With some grip this would improve again,, at a guess out to 128mph....this on 11psi so LESS boost than what i was running on the stock manifold at 12.5psi.
Bodes well for the top end gain....takes a fair bit of extra grunt to see a 8mph gain in trap speed
Considering offers
Considering offers
